es:original:engine [2020/01/23 01:22] – [2.5L Diesel (VM Motori VM425)] Wolfram | es:original:engine [2022/09/03 12:52] – Externe Bearbeitung 127.0.0.1 | ||
+ | ====Injektoren ==== | ||
+ | |4418661 |1991 |3.3L |Schwarz| | | ||
+ | |4612176 |1992 |3.3L |Violett| | | ||
+ | |4612176 |1993 |3.3L |Violett| | | ||
+ | |4612177 |1993 |3.8L |Blau|Bosch 0280150957 | | ||
+ | |4612402 |1994 |3.3L |Orange|Siemens Deka | | ||
+ | |4612177 |1994 |3.8L |Blau|Bosch 0280150957 | | ||
+ | |4612402 |1995 |3.3L |Orange|Siemens Deka | | ||
+ | |4612177 |1995 |3.8L |Blau|Bosch 0280150957 | | ||
