es:original:engine [2020/05/21 09:12] – [2.5L Diesel (ENC) (VM Motori VM425)] Wolfram | es:original:engine [2023/09/05 20:07] – [Injektoren] Wolfram | ||
+ | |4612177 |1993 & 1994 & 1995 |3.8L |Blau|Bosch 0280150957 |~Ω | | ||
