es:original:engine [2020/02/01 11:49] – [Zylinderköpfe] Wolfram | es:original:engine [2023/11/08 09:27] (aktuell) – Externe Bearbeitung 127.0.0.1 | ||
+ | |4612177 |1993 & 1994 & 1995 |3.8L |Blau|Bosch 0280150957 | ~14,9Ω | | ||
