es:original:engine [2020/08/07 08:25] – [2.5L Diesel (ENC) (VM Motori VM425)] Wolfram | es:original:engine [2023/11/08 09:27] (aktuell) – Externe Bearbeitung 127.0.0.1 | ||
+ | |4612177 |1993 & 1994 & 1995 |3.8L |Blau|Bosch 0280150957 | ~14,9Ω | | ||
