glossary [2019/12/17 07:27] – Wolfram | glossary [2023/01/21 15:30] (aktuell) – Wolfram | ||
+ | ====== Glossar Chrysler ====== | ||
+ | ^Abkürzung ^Bedeutung ^Übersetzung ^ | ||
+ | |ABS |Antilock Brake System |Antiblockiersystem | | ||
+ | |AIS |Automatic Idle Speed |Leerlaufregler | | ||
+ | |ASD |Automatic ShutDown |Notabschaltrelais für Benzinpumpe/ | ||
+ | |ASDM |Air Bag System Diagnostic Module |Airbag-Steuergerät | | ||
+ | |ATF |Automatic Transmission Fluid |Getriebeöl | | ||
+ | |AWD |All Wheel Drive |Allrad | | ||
+ | |BUX |Build-Up-Export |Exportfahrzeug für andere Märkte | | ||
+ | |CAB |Controller Antilock Brake |ABS-Steuergerät | | ||
+ | |CCD |Chrysler Collision Detection |-| | ||
+ | |CMTC |Compass Mini-Trip Computer |Bordcomputer | | ||
+ | |CPS |Crank Position Sensor |Kurbelwinkelgeber / Kurbelwellenensor | | ||
+ | |DRB II/III |Diagnostic Readout Box II/III|-| | ||
+ | |EATX |Electronic Automatic Transaxle |Getriebe-Steuergerät | | ||
+ | |EMCC |Electronically Modulated Converter Clutch | | | ||
+ | |EVAP |Evaporative System |Tankentlüftung Benzingase | | ||
+ | |EVIC |Electronic Vehicle Information Center |Bordcomputer | | ||
+ | |ECM |Engine Control Module |Motor-Steuergerät | | ||
+ | |EFI |Electronic Fuel Injection |-| | ||
+ | |EGR |Exhaust Gas Recirculation |AGR / Abgasrückführung | | ||
+ | |EWB |Extended Wheelbase |Langer Radstand | | ||
+ | |FWD |Front Wheel Drive |Frontantrieb | | ||
+ | |HVAC |Heating, Ventilation & Air Conditioning|Klimabedienteil | | ||
+ | |IAC |Idle Air Control |Leerlaufregler | | ||
+ | |LM |Logic Module |-| | ||
+ | |LWB |Long Wheel Base |Langer Radstand | | ||
+ | |MAP(-Sensor) |Manifold Absolute Pressure (-Sensor) |Unterdruck(sensor) Ansaugbrücke | | ||
+ | |MPI |Multi Point Injection| | | ||
+ | |O/D |Overdrive |-| | ||
+ | |PCI |Programmable Communication Interface |-| | ||
+ | |PCM |Powertrain Control Module |Motor-Steuergerät | | ||
+ | |PCV |Positive Crankcase Ventilation |Kurbengehäuseentlüftung | | ||
+ | |PTU |Power Transfer Unit |Allrad Verteilergetriebe | | ||
+ | |RKE |Remote Keyless Entry |Funkfernbedienung | | ||
+ | |SBEC |Single Board Engine Controller |Motor-Steuergerät | | ||
+ | |SFI |Sequential Fuel Injection |-| | ||
+ | |SCI |Serial Communications Interface |-| | ||
+ | |SMEC |Single Module Engine Controller |Motor-Steuergerät | | ||
+ | |SWB |Short Wheel Base |Kurzer Radstand | | ||
+ | |TBI |Throttle Body Injection |Sammeleinspritzung | | ||
+ | |T&C |Town & Country |- | | ||
+ | |TCC |Torque Converter Clutch |Wandlerbrücke / Wanderüberbrückung | | ||
+ | |TCM |Transmission Control Module|Getriebe-Steuergerät | | ||
+ | |TPS |Throttle Position Sensor |" | ||
+ | |WSS |Wheel Speed Sensor |Rad-Drehzahlsensor (ABS) | |
